Sponsored by: CARiD
Front passenger regulator woes
Old Jun 15, 2016 | 02:24 PM
Rwcmick's Avatar
Default Front passenger regulator woes
2004 discovery with an issue. I had to replace the regulator due due a broken nylon part. The usual story. I reassembled everything and it worked really well. Sealed up the door and went on my way. Day later I'm testing the window again just because I am like that. After a few up/down runs of perfection, I spot impending doom. I notice that on the way up the window starts to go up at faster and then slower speeds. Hmm that isn't normal. So then i roll it down again halfway. Then I try to roll the window up and the window doesn't move. Sounds like an air wrench wrapping sound when it hits the torque limit. I thought it was maybe the motor not meshing with the gear on the regulator so I took it all apart and reconnected to the motor to the regulator. Same sound when i reassemble, not even one successful run. The gear on the motor doesn't look worn or stripped. The motor looks meshed together with the regulator. What could it be? I am able to manually lift the window up, albeit with some effort.
Marni
Sep 15, 2011 10:03 AM
Gerard
May 27, 2011 09:57 AM
Spencerfitch
May 3, 2010 02:56 PM
Yikes!
Apr 23, 2010 01:23 PM
dcreekmore44
May 7, 2009 02:21 PM
