Front Sagging on 07’ LR3
Just bought my first LR3 a couple of weeks ago in Chicago from a dealer that didn’t know what they had (I guess). Flew out, picked it up for 11.5k, and found out that it had a refrigerated center console and HD package. After driving a few weeks, I’m at 64500 and I’ve noticed it will correct the suspension height at times and the compressor runs frequently.
The compressor has been replaced twice by the first owner, and I’m wondering if it’s a front valve issue like a lot of other people have written about. I removed the compressor relay and noticed that the front driver and passenger side were significantly lower than the rear this morning. If measurements would help I can do the same tonight and report back.
I know I have to replace the front passenger side hub bearing assembly, and I just replaced the pcv and coolant bleeder t after it cracked 700 miles away from home (awesome), so I’d like to pinpoint the problem before throwing a wad of cash at the parts dept to find out that didn’t remedy the issue. Kind of hard to do when there aren’t any fault codes
Thanks,
AR
Thanks,
AR
