Sponsored by: CARiD
Front Wheel Bearing Locknut
Old Jun 21, 2006 | 02:40 PM
btp226's Avatar
Default Front Wheel Bearing Locknut
What size are the two nuts that hold the front wheel bearings on? I need to set the bearing pre-load after replacing the brake rotors, and realize I don't have anything that will fit. (The outer one came off using a standard adj wrench, and the inner was only finger tight)
I measure the nut to be ~2 1/16", is that correct or is it a metric?
This is for a 1995 Disco.
Thanks,
Brian
Old Jun 21, 2006 | 05:01 PM
Landzu's Avatar
Default RE: Front Wheel Bearing Locknut
2 1/16 is right.
Old Jun 21, 2006 | 05:35 PM
btp226's Avatar
Thank you!!!
Brian
Grlica
May 1, 2013 06:13 PM
bagocheetohs
Jul 1, 2011 06:01 PM
Garrett
Sep 28, 2010 05:41 PM
bhowell
Mar 25, 2009 01:10 AM
sdsilvere38
Sep 16, 2008 09:32 PM
