Sponsored by: CARiD
Fuel or ignition module trouble?
Old Sep 13, 2019 | 06:30 PM
RRC4.2's Avatar
Default Fuel or ignition module trouble?
Hi, has anybody got any solutions for my RRC?.
first problem is hot starting. Starts first pop when cold but it once she’s hot, reluctantly starts after 5-10 seconds of cranking. I’ve read elsewhere that it could be the crank position sensor. Is this a correct diagnosis? Or fuel pressure? Ignition module
Second problem is rather more in depth. Once running, idles fine, but upon acceleration she sort of hesitates, not misfires or popping, and once cruising, she continues to hesitate. The engine’s not cutting out completely, just this sort of on-off sort of thing. When you put your foot up it, away she goes, but once back to cruising, the hesitation returns.
My first simple task will be to change the fuel filter....
1993 RRC
Anyone have similar symptoms?
Old Sep 17, 2019 | 07:35 AM
WaltNYC's Avatar
Crank sensor and/or damaged tabs on the reluctor ring is a good place to start. I'd check the tabs first by removing the bell housing inspection plate (half moon shaped plate right behind the oil pan) and visually inspect the tabs.
My truck ate a starter (long story) and I checked the flex plate. Here is what your starter ring and reluctors should look like. Ignore my long boring diatribe. Probably best to view on mute.
mr. choodles
Jul 6, 2018 07:37 AM
Walko327
Mar 10, 2013 09:45 PM
Joshbstuck
Jan 16, 2013 01:26 PM
nelbra
Jul 8, 2010 11:47 PM
crownaviation
Jan 12, 2008 09:52 PM
