Sponsored by: CARiD
Fuel pump or vehicle speed sensor, OR...?
Old Jul 14, 2014 | 07:29 PM
4Low's Avatar
Default Fuel pump or vehicle speed sensor, OR...?
Been having some problems recently with the throttle cutting out at speed. My first thought was the vehicle speed sensor but I'm not too sure. It seems to fit all the signs, but will still cut out in 3rd, not just D.
Also, my fuel pump has had some problems since I have owned the rig. Usually though its only if its below freezing outside, and only lasts till the engine is warmed up. I've also had a check engine light for a while and the code that comes up is for a cam shaft position sensor, could that be causing this?
The speedometer has cut out once, but usually doesn't.
Should I just take the speed sensor off and see what happens? In theory it shouldn't mess with anything besides disabling the speedometer right? So if I take it off and still have problems then its something else?
Also, where can I buy this sensor? I've found a few online for less than $100 although they are all out of stock. Only ones I've found in stock are over $300 and that seems ridiculous. Checked atlanticbritish, amazon, parts geek, etc.
Old Jul 15, 2014 | 06:48 PM
4Low's Avatar
No one? Any tips on how to find the thing so as to take it off would be appreciated. Looked at what I'm pretty sure was the transfer case but couldn't find anything that looked like the pictures of the sensor I found online.
tcbinaflash
Nov 27, 2018 06:32 PM
vorticistssuite
Nov 23, 2013 03:20 PM
southernrover
Aug 8, 2011 01:49 PM
grussell
Oct 6, 2009 08:14 PM
ajordan_0012000
Feb 20, 2009 02:19 PM
