Fuel System Leak? Can't find it...
Old 07-17-2008, 02:57 PM
TWALDBILLIG's Avatar
Default Fuel System Leak? Can't find it...
I took my 2000 Discovery to two local dealers to solve the Check Engine light mystery. Neither have been able to so I'm turning to you all for help. The code is the "Gas Cap Code" that keeps faulting. Both dealers agreed. The first dealer completely replaced the gas cap and the housing they also performed a "smoke test" during which they found no leak. When the light continued to turn on and off I took it to another dealer. They said they could not find the leak during the smoke test either. At the time I took it to the two dealers it was still covered under an aftermarket warranty. It is no longer covered and I don't trust either of the dealers to fix the problem on my dime when they couldn't under warranty.
What is the next most likely part to be faulty causing this fault over and over???
Old 07-17-2008, 08:44 PM
Default RE: Fuel System Leak? Can't find it...
What is the exact code??? We need that to be able to help you.
Sounds like you may have one of the evap codes, but very few mean you have to replace the fuel cap.
1999SE40
05-16-2014 09:55 AM
blast20
09-03-2010 12:18 AM
Wifes Disco ll
03-06-2008 12:17 PM
jmerrill
12-06-2006 11:59 AM
Quick Reply: Fuel System Leak? Can't find it...
