Sponsored by: CARiD
Which Gas To Choose?
Old Apr 22, 2012 | 07:48 PM
  #21
oilspotLR's Avatar
I found this page in the LR3 "rave" I downloaded, it does say premium (91) for NAS, ROW says 98 (using a different measure). This is for the V6.
I wonder why though, especially if the ford v6 in the f150/explorer doesn't need premium....
Old Apr 22, 2012 | 09:49 PM
  #22
Banzai Jimmy's Avatar
Different timing curve would do it. If LR put a more aggressive timing curve into the computer, then you'd need the higher octane to prevent pre-ignition/detonation.
Don't know if that's it (assuming the internals of the engines are the same) - just an idea off the top of my head.
Old Apr 23, 2012 | 07:03 AM
  #23
roverguy67's Avatar
I have had my 2000 DII since 1999 and have only run 92 octane or higher..... It runs BAD on regular( I can ALWAYS tell when my step son has put bad fuel in my truck!!). I would suggest only premium fuel......just sayin...
Old May 14, 2012 | 08:42 AM
  #24
jbunner's Avatar
My '95 takes premium. I have tried the lower octane, won't go up the hills in WV. Knocks, etc. The manual say 95 octane which I can't even find. The premium here is 93 octane. I even tried putting octane booster in to no avail. Just have to bite the bullet and pay for premium if I want to drive the thing.
Old May 14, 2012 | 07:56 PM
  #25
95 octane is in Europe, not the US.
Octane booster actually lowers your octane rating and even if it did work think about it.
$5 for a bottle of octane booster for every tank of gas, or just pay the extra $5 to fill up with premium.
Old Oct 9, 2012 | 11:20 PM
  #26
rallyemax's Avatar
3rd Gear
Originally Posted by Spike555
Well on a non dizzy engine the knock sensors retard the ignition timing to adjust for the lower octane fuel.
On a dizzy engine YOU have to retard the ignition timing to adjust for the lower octane fuel, if you dont you will get spark knock (you may not hear it) and as we all know from high school auto shop spark knock over extended time will destroy a engine.
How much you need to retard the ignition timing I have no idea.
Now I will confuse you even more, there were a small number of low compression 3.9's imported to the US, those only require 87 octane, the compression ratio on those engines is 8.35:1 compared to the 9.35:1 on the "high" compression engines.
I do not know how to tell which engine you have.
On a D1, the compression ratio should be stamped immediately above the engine serial number.
If the ratio is 8.13, the manual states to use 91 RON, which equates to 86-87 "American" octane (AKI).
If the ratio is 9.35, the manual states to use 95 RON, which comes out to 90-91 "American" octane (AKI).
Remember those figures are for sea level. Lower octane fuel may be used at altitude (this is why in the Rocky Mountain states, fuel is sold at 85, 87, and 91 octane...in lower-lying regions, it's sold at 87, 89, and 93, respectively).
PostRelease
Jun 18, 2009 01:00 PM
sheeva
Nov 3, 2008 01:42 PM
bravo1
Mar 19, 2007 09:17 AM
pleojon
Dec 28, 2006 01:55 AM
hook22
Dec 16, 2006 03:47 AM
