Sponsored by: CARiD
Gear box
Old May 22, 2015 | 07:26 PM
Etpoon's Avatar
Default Gear box
Help please. Just bought a series 3 swb which ran perfectly for the first day but when I engaged 4 wheel drive and low range the car won't engage in any gear high or low range. When the clutch is released the gear box makes a whirring sound as if it's not properly engaged.
Old May 29, 2015 | 01:31 PM
4LR4's Avatar
4wd High
Have you checked the Main Gear Box and Transfer Box oil levels? I had a similar problem however just the whining noise when the clutch was not engaged…throw out bearing was slipping. There was very little oil in the Main Gear Box. Once filled up it worked fine.
Just a thought.
Michael
1981 Series III Santana 109
Old May 29, 2015 | 01:48 PM
justryan's Avatar
Sounds like your clutch release bearing is bad ....
wickham
Jan 8, 2007 08:26 PM
ant996
Defender
Sep 14, 2006 05:03 AM
Grtis1
Aug 7, 2006 03:32 PM
99Landrover
Mar 15, 2006 11:08 PM
richukbrb
Mar 14, 2006 12:34 AM
