Sponsored by: CARiD
gearbox warning signal
Old Nov 4, 2008 | 09:05 AM
rjmatteson's Avatar
Default gearbox warning signal
Has anyone had experience troubleshooting the green S and M (snow and manual) lights flashing indicating a gearbox electrical problem? plus I have a short in the steering wheel causing the horn to blast at inappropriate moments.
thanks
richard
inappropriateinappropriate
Old Nov 4, 2008 | 09:42 AM
Default RE: gearbox warning signal
First thing to check you battery cables, are they clean and tight? Then check the voltage, 12.8 at idle and 13.6 to 14.4 volts at 2000 RPM's. If you have low voltage the M/S lights will flash.
Old Nov 4, 2008 | 10:10 AM
rjmatteson's Avatar
thanks DMike, I will check into all of that,
cheers richard
cipher982
Nov 9, 2019 11:22 AM
range_rovin1986
Mar 29, 2007 06:43 PM
freeranger
Mar 29, 2005 06:03 PM
dannyc
Feb 15, 2005 04:37 PM
