Sponsored by: CARiD
GEMS 4.0 VERSUS BOSCH 4.0 (No LEV)
Old Jul 8, 2011 | 11:50 AM
David Kadasia's Avatar
Default GEMS 4.0 VERSUS BOSCH 4.0 (No LEV)
"Success is going from failure to failure and not loosing enthusiasm"
I wonder if the gems(95-98) and bosch(99-2002) engines share the basic block, crank, heads,rockers, camshaft, lifter parts, front timing cover c/w oil pump and water pump? Other than fuel injection system, the only difference I can find is the crank shaft position sensor (gems) versus electronic speed sensor (Bosch). If i am correct I should be able to buy a rebuilt long block (Bosch), install my gems intake manifold, install my gems antiknock sensors, gems timing cover, fabricate crank position sensor from Gems and be good to go.
What I am contemplating, is taking a 2002 Bosch long Block into a 1998 Range Rover...doable?
Thanks for your response...
Dave
Old Jul 8, 2011 | 02:17 PM
Yes it is doable, that being said, the late gems motors were made from a better alloy then the D2 engine so if you are looking to rebuild go for a 97 thru 99 Gems engine
Old Jul 8, 2011 | 07:08 PM
Quality control during the Bosch years was not of any importance.
A Gems engine is the better of the 2.
But yes, they are the same block and heads.
Old Jul 8, 2011 | 10:12 PM
Default Gems it is..
Thank-you....
Old Jul 14, 2017 | 08:55 AM
dwatterson1's Avatar
how many antiknock sensors on a 2003 d2 , 4.6
Old Jul 14, 2017 | 09:42 AM
OverRover's Avatar
There are 2 knock sensors > Replacing The Knock Sensor On A Discovery 2 Or Range Rover.
Just a FYI, you might want to post a new question like this in the DII Section (this thread is from 2011) you will get more eyes on it.
Cheers
Old Jul 15, 2017 | 10:22 AM
thx for the help
WARWAGON
Sep 3, 2012 03:20 PM
BW_Hunter
May 24, 2012 01:56 PM
toad2
Aug 19, 2010 09:13 AM
garcia1000
Nov 24, 2009 10:30 AM
MOTERO5
Mar 26, 2009 10:30 PM
