Sponsored by: CARiD
has any one else ever delt with this
Old Aug 5, 2012 | 10:56 PM
cbr929rroo's Avatar
Default has any one else ever delt with this
96 disco sd new problem. have a vacuum leak on the truck with furher inspection i found both injectors on the drivers side ( both middle ones )
have vacuum leaks. they are after market so im going to change them back to stock. has any one else ever come across this problem?
Old Aug 6, 2012 | 03:21 PM
Scharfire's Avatar
nope sure have not. what part of NV are you from?
Old Aug 6, 2012 | 08:54 PM
So the o-rings on the injectors is bad?
Thats a new one, replace them, the o-rings I mean.
Old Aug 7, 2012 | 10:39 PM
cbr929rroo's Avatar
not sure of o-ring being bad, but guess i have to just tear it apart and see. And Scharfire just out side of las vegas
Old Aug 11, 2012 | 06:43 PM
Rovin4life's Avatar
you don't get vacuum leaks in injectors you get leaks outright. its possible the aftermarket ones are putting too little fuel.
Old Aug 12, 2012 | 09:08 AM
Scharfire's Avatar
ahh im from las vegas. ill be moving back down there in about 6 months. i will be in parhump.
Old Aug 12, 2012 | 03:24 PM
cbr929rroo's Avatar
Rovin4life: you can actually hear vacuum from the injectors and when sprayed with cleaner the idle picks up. I have also had a problem with the truck burning rich. And having no power when it is warmed up, tons stay close to the same but mph drops.
Old Aug 12, 2012 | 03:27 PM
cbr929rroo's Avatar
Scharfire: I'm located in pahrump for now till we move.
Old Aug 12, 2012 | 05:26 PM
Scharfire's Avatar
to funny. ill actually be in pahrump in 3 days.
DonRW2007
Appearance & Camping Set Ups
Apr 2, 2012 06:26 PM
skezixx
Off Topic
Nov 2, 2011 02:42 PM
JayhawkinIdaho
Mar 9, 2008 06:46 PM
