Sponsored by: CARiD
Head gasket?
Old Jul 20, 2016 | 01:16 PM
MysteeklRover's Avatar
Default Head gasket?
I have an 02 disco 2 and it doesn't overheat or smoke, but it is LOUD! It sounds like a train and it sounds like the problem is coming from the left side(drivers side) and after driving a while, at a stop, it smokes a little from that area but out the side from under hood...it has 158800 miles and noise is worse when I push on the gas. I cansmell exhaust fumes pretty strong, too.....ideas?
Old Jul 20, 2016 | 03:29 PM
d.a.r.y.l's Avatar
Loose or broken exhaust manifold? Any codes? D*
Old Jul 20, 2016 | 05:11 PM
abran's Avatar
Check the exhaust manifold as said above, but most of the time that is a blown head gasket that is pushing out externally. A leak down test is the way to know for sure unless you can feel the air push out from the head/block seam.
Old Jul 20, 2016 | 08:56 PM
number9's Avatar
Unless engine kept clean may just be leaked oil accumulation heating up and smoking off from leaky manifold. May the RGs be with you.
Old Jul 26, 2016 | 05:39 AM
loanrangie's Avatar
Check the exhaust manifolds for loose nuts or broken studs,blown head gasket wont produce excessive exhaust fumes.
mike111
Jun 2, 2014 08:58 AM
FlyingZebra34
Apr 25, 2013 08:04 AM
jpmiller
Sep 26, 2012 06:32 AM
dancedisco
Feb 6, 2012 06:34 AM
jcostello
Nov 2, 2006 10:28 PM
