Sponsored by: CARiD
Head gasket replacement
Old Jun 24, 2011 | 10:08 PM
hockeymom1's Avatar
Default Head gasket replacement
On my 2000 land rover disco II, what is recommended to be replaced in addition to, when I am doing a head gasket replacement?
What head gasket is recommended the composite or other?
Thanks,
Patrick
Old Jun 25, 2011 | 08:08 PM
Just order the composite kit from AtlanticBritish, it will have everything you need including head bolts.
You might want to also replace the throttle body heater gasket.
Also switch from Dex-Cool to any aluminum safe coolant you want.
Old Jun 26, 2011 | 01:40 AM
hockeymom1's Avatar
Thanks much!
Old Jun 28, 2011 | 08:36 AM
drowssap's Avatar
make sure you order the upper intake gasket it does not come with the kit, unless it has changed in the last couple of months.
Old Jun 28, 2011 | 09:11 AM
Also plan on a new t/stat, coolant cap and 8 mm plug wires.
Do you have a Rave or shop manual to get instruction from?
Old Jun 28, 2011 | 12:16 PM
hockeymom1's Avatar
Smile
Too bad I can't order a new car at the same time, maybe one I can drive thanks for giving my husband all the wonderful advice. Monica
Old Jul 2, 2011 | 12:46 AM
priceg's Avatar
How many miles?
bennyb43
Nov 28, 2015 04:01 PM
mike111
Jun 2, 2014 08:58 AM
FlyingZebra34
Apr 25, 2013 08:04 AM
dancedisco
Feb 6, 2012 06:34 AM
jcostello
Nov 2, 2006 10:28 PM
