Head gaskets repair 2003 disco
![Unhappy](https://landroverforums.com/forum/images/icons/icon9.gif)
Guys, this is my first post, but all of you have helped me many times in the past with my truck. I am currently being told that I need to replace my head gaskets. I believe this as I do have some oil and coolant leaks. However, my disco is within the dreaded VIN# range of the problem discos. So, should I finally let my disco die? Is it a concern that my disco is within the range of bad vin#s given the new developments? I just learned of this bad vin issue recently and I have owned the truck for 4 years. In the last two years I have replaced the radiator, the thermostat, rotors, brakes, rear diff, and O2 sensors. I also had a shop do a new tune up with new plugs and wires about a year ago.
My info:
2003 Disco
93,000miles
My info:
2003 Disco
93,000miles
No, the dreaded VIN range was that "some" units within that range had an alignment problem with the front cover that buggered up the oil pump, and these failed before 50,000; Rover replaced engines. Your's was one of the OK ones that is just subject to regular Disco problems.
Many oil leaks are caused by the valve cover gaskets, you should snug those four bolts up (8mm 12 point, skinny socket). Where is coolant leaking? How much in a week?
An indy shop will charge between 1700 - 2500 for HG. Dealer will be higher. DIY is $200 ish gaskets kit and new bolts, $250 ish to get heads skimmed and valve seals done; plus your labor. Lot of guys leak more oil than you, could be anything from valve covers to rear main seal to oil pan gasket.
RROJ
03-26-2011 02:37 PM
starrock
02-20-2010 09:23 PM
