Sponsored by: CARiD
Help! 04 Discovery didn't crank up til 4th try
Old Sep 14, 2005 | 11:05 PM
rebel1's Avatar
Default Help! 04 Discovery didn't crank up til 4th try
My 04 Discovery didn't crank up this afternoon until the 4th try.
After it started my A/C display registers 16 as low and 28 as high & The clock lost the current time.
Could this be an Electrical Fuse problem or Battery problem? Any advice? Thanks!
Old Sep 18, 2005 | 09:32 PM
modyfyit's Avatar
Default RE: Help! 04 Discovery didn't crank up til 4th try
check your battery
Old Sep 21, 2005 | 02:38 AM
thatymer's Avatar
you can load test the battery to check it as said by the above post. and try to look up for the battery cable connections. it should be clean to avoid cranking problems.
Old Sep 21, 2005 | 08:15 PM
duboff's Avatar
first if it is under warrenty then off to the shop. If not, then check all of the grounds on the vehicle. specifically the battery for a good connection. It also may be a low voltage drain on the battery. If you end up having to replace the battery, i recommend a high quality deep cycle battery. hope it helps. gotta love a rover. duboff
Old Sep 22, 2005 | 01:10 AM
modyfyit's Avatar
optima...
Old Oct 7, 2005 | 09:41 PM
rinmud's Avatar
ground wire is ****ed up replace it
Old School
Feb 14, 2008 04:13 PM
Lar45
Jan 21, 2008 08:26 PM
wvcox1
Sep 12, 2007 05:25 PM
