Sponsored by: CARiD
Help
Old Dec 10, 2012 | 11:03 PM
iddisco's Avatar
Default Help
I have the engine code p0414. There is exhaust coming out my sai pump and its quite loud. I don't think the pump is functioning. The solenoid has been replaced and I have checked the voltage And the solenoid is always engaged or grounded. In my mind that means either bad wiring to solenoid from ecu or bad ecu? Could the CPU leave the valve open if its getting a bad reading from say the maf or temp sensor? I will be replacing the pump but need the valve to work properly first. For context it's a 2001 disco with 175,000 miles. Any suggestions?
Old Dec 11, 2012 | 12:17 AM
P0414 SAI vacuum solenoid valve short circuit to ground
I'd be looking at wiring and connectors, and the harness. A "ground" can be something as simple as a skinned wire touching metal.
Speed racer
Oct 11, 2008 10:56 PM
Roca316
Mar 18, 2008 11:33 AM
scottinoz
Jun 30, 2007 09:49 AM
cassie11
Jun 23, 2006 10:26 AM
