Sponsored by: CARiD
Help. Disco II towed twice.
Old Dec 7, 2011 | 09:03 PM
kevinb91's Avatar
Yes Both the camshaft and crank sensors are new
Old Dec 7, 2011 | 09:17 PM
Well, you start at fuse 13 in the underhood box. Go out on a brown & black wire to the inertia switch, thru that , back on white green to supply 12 volt power to main relay. Could bypass inertia switch for testing, but it is a serious safety item, kills fuel pump and unlocks doors in a crash.
But that does not explain buzzing.
The ECU provides a ground to turn on the main relay, on a blue-red wire to pin 23 on the ECU. Guess you could have a skinned wire making a ground, but that should not turn the relay off when driving.
Old Dec 7, 2011 | 09:34 PM
kevinb91's Avatar
I will check all of those things in the morning. Thank you
cybercop
Sep 25, 2014 10:27 PM
JayhawkinIdaho
Mar 9, 2008 06:46 PM
azdesertdog
Dec 16, 2006 11:54 AM
quattro
Aug 1, 2006 12:32 AM
Doss
Apr 12, 2006 03:32 AM
