Sponsored by: CARiD
Help I'm new
Old Jan 14, 2017 | 08:38 AM
Patriotwac5's Avatar
6th Gear
Default Help I'm new
Hey guys, I need some help.
I have a 1988 LR Classic. It's had some work done to it . But it's leaking oil, I think. I just had my timing chain changed and all my oils and fluids changed. After I am leaking some sort of oil, I believe its engine oil. It's from the front of the vehicle. It's a bit much for comfort but I check all my fluid religiously and they don't change? Any ideas???
Old Jan 14, 2017 | 09:37 PM
XCELLER8's Avatar
take it for a drive and park it,put a piece of cardboard underneath and wait for the drips to appear....it will be easier to find that way....could also be transmission fluid ( ATF--red ) or the power steering,
Old Jan 16, 2017 | 03:56 PM
ihscouts's Avatar
Based on the work you recently had done it kind of gives clues. The oil pump is mounted to the front cover, check it's connections and that the filter is tight. There is an oil seal in the cover behind the crank shaft pulley. If the oil seal was nicked (or old and dry and not replaced) it will leak oil while the engine is running. The timing cover gets bolted to the block and the front of the oil pan gets bolted to the timing cover, check that area. The cover itself might not have sealed well to the block so check it for leaks.
Speed racer
Oct 11, 2008 10:56 PM
Roca316
Mar 18, 2008 11:33 AM
scottinoz
Jun 30, 2007 09:49 AM
cassie11
Jun 23, 2006 10:26 AM
