I have land rover discovery and have had 3 rubber coupling fitted in the last 6 months, the nuts just through the side of the coupling if any one can help me please let me know as soon as possible.
Hi ,I recently changed mine over for a defender type no rubber coupling on drive shaft,its a kit and price is worth it.No more cracked rubber and much more reliable,hope this helps
Its installed wrong. I bet if you put the car on a lift and watch the thing operate in drive you will see it wobble itself. You might need a pinion bearing or the shaft is frozen.
