Sponsored by: CARiD
Help with rubber coupling
Old Aug 25, 2011 | 10:25 AM
wendydenny27@hotmail.co.uk's Avatar
Unhappy Help with rubber coupling
I have land rover discovery and have had 3 rubber coupling fitted in the last 6 months, the nuts just through the side of the coupling if any one can help me please let me know as soon as possible.
Old Aug 25, 2011 | 07:51 PM
Are you using a OEM one or aftermarket?
Are you installing it facing the correct way?
Do you have a lift of more than 2"?
Old Aug 25, 2011 | 08:21 PM
Good question.
Old Aug 26, 2011 | 08:23 AM
4xbee's Avatar
4th Gear
Hi ,I recently changed mine over for a defender type no rubber coupling on drive shaft,its a kit and price is worth it.No more cracked rubber and much more reliable,hope this helps
Old Aug 26, 2011 | 09:06 PM
Rovin4life's Avatar
Its installed wrong. I bet if you put the car on a lift and watch the thing operate in drive you will see it wobble itself. You might need a pinion bearing or the shaft is frozen.
thestimes
Apr 15, 2015 06:19 PM
bradical
Oct 18, 2011 11:44 PM
jenniemcl
Jan 15, 2011 07:10 AM
Torancis_LR
Jun 15, 2009 02:55 PM
ScottM
Dec 26, 2006 07:14 PM
