Sponsored by: CARiD
Help trouble shooting
Old Jan 4, 2018 | 11:00 PM
Klynn's Avatar
4th Gear
Default Help trouble shooting
Mi was driving my Land Rover discovery 2 and I was coming to a stop sign and my Rover lurched as I stopped, when I proceeded to go when it was my turn my Rover wouldn’t move, it was like it was in park . I looked at the dash and had a symbol of two gears with the letters TC below them. I had no problems before this happened. Any ideas what is going on with it?
Old Jan 5, 2018 | 06:37 AM
mollusc's Avatar
Your transfer case has come out of gear. Check the high-low range lever.
Old Jan 5, 2018 | 06:43 AM
Klynn's Avatar
4th Gear
Default Troubleshooting
Ok I will check that and see if that’s the problem. Thank you
Old Jan 5, 2018 | 08:26 AM
alpinacsi's Avatar
So how did you get out of the intersection? Did it clear itself or did you have it towed.
Old Jan 5, 2018 | 04:51 PM
Klynn's Avatar
4th Gear
. We pushed it to the side of the road and had it towed from there. It’s a 2000 Land over discovery 2
Old Jan 5, 2018 | 04:58 PM
mollusc's Avatar
Sorry, I don't know where my head was this morning. Transfer case would have been accompanied by a chime and would have been a different light -- kind of an orange X thing. TC is Traction Control.
Old Jan 6, 2018 | 01:29 PM
Klynn's Avatar
4th Gear
Default Traction control
what do I need to do for the traction control, I’m sorry I. Don’t know much about cars I’m trying to get info for my husband
Old Jan 6, 2018 | 02:09 PM
mollusc's Avatar
The following is copied from the Land Rover service manual (the 'RAVE'):
The traction control warning lamp within the instrument pack utilises a red LED and a clear legend. The traction control warning lamp informs the driver that the traction control system is enabled. The warning lamp is hard wired to the SLABS ECU. The SLABS ECU controls the warning lamp on or off via a high or low voltage signal to the instrument pack.
When the ignition is switched on, the SLABS ECU illuminates the LED to provide a self-check, providing there is no fault it will remain illuminated for 3 seconds or until the ignition is switched off.
The SLABS ECU is one of the computers in the truck. It sounds to me like a sensor is sending a fault warning to the computer. You will need to borrow a code reader to see if there are any codes in the system that will point you in the right direction.
vonrock
Feb 3, 2013 10:42 AM
coldstart
May 8, 2011 07:01 PM
rmassaro
Aug 5, 2010 08:44 AM
jons.cars
Jun 1, 2010 06:54 AM
2000rrhse
May 30, 2007 04:37 AM
