Sponsored by: CARiD
Is there a Discovery Electronic Trouble Shooting Manuel available?
Old May 31, 2010 | 02:48 PM
jons.cars's Avatar
3rd Gear
Default Is there a Discovery Electronic Trouble Shooting Manuel available?
Cranks, won't start with out starting fluid.
I have electrical test equipment (scanner, test light, and digital multimeter) but do not have much experience using them.
Test light shows power getting to the main relay and the fuel pump relay (appears that a PO had opened and resealed relay casing). I am not sure how to test if power is leaving the relays with out damaging the coating on the wires.
None of the pins on the harness at the pump show power getting there, nor which wire to add power to, to test the pump.
The Workshop manual for DISCOVERY that I down loaded (from this forums recommended link) mentioned a Discovery Electronic Trouble Shooting Manuel. Is this also a free resource available?
The ECM has been changed out by a PO.
The Inertia switch was loose from the chassis and 'clicked' when I pushed down on the central plunger.
Most of the codes (P:1193,1187,1179, and 1177) most likely are caused by a missing factory air filter case (aftermarket K&N air filter installed by PO), so the Intake air temperature sensor is just laying in the ambient air.
The other code P0138 is an O2 sensor, but that would not cause a no start issue would it.
History that may be relevant: A couple years ago when I bought the truck, when I have had issue with it starting I found a 'hot spot' at the harness to pump connection at the pump and a spliced in section of the harness where the pig tail had been replaced. Everywhere I safely put the test light I get no power back there now.
1997 Discovery SE 188,008 4.0L SFI V8i
Old May 31, 2010 | 03:10 PM
Rovin4life's Avatar
power goes from the fuel pump relay to the inertia switch. if you got it past there its the wiring back perhaps near the driver rear tire.
plus you should have two power lines one from the satelite fuse box and the other from the main fuse box. the ecu grounds the one side and the other goes to the inertia switch.
if the ecu isn't grounding then you have to look from there.
Old Jun 1, 2010 | 06:54 AM
antichrist's Avatar
The ETM is on the RAVE CD.
olywa
Nov 21, 2013 01:07 PM
vonrock
Feb 3, 2013 10:42 AM
coldstart
May 8, 2011 07:01 PM
rmassaro
Aug 5, 2010 08:44 AM
2000rrhse
May 30, 2007 04:37 AM
