High pitched whine at 70-75mph
First, thanks for any assistance with this. My LR Disco is a 2000 model with 56k on the odo.
I recently had my transfer case replaced (at 46k miles) because, in all likelihood, the 30k service wasn't performed (bought used with 44k miles). The indicator of a problem was a high-pitched whine at hwy speeds, the longer I drove the more notable the whine.
Now, with 10k on the new transfer case, I'm hearing the same high-frequency whine, generally between 70 and 80 mph. Note that it lessens when letting up on the accelerator, and vanishes when letting off the accelerator completely. Is it possible my transfer case is going again after only 10k? And if so, any ideas why?
Or, are there other issues I should consider? I had the transmission serviced when the trnsfr case was replaced (46k) so I'm hoping it's not that.
Don't have much mechanical aptitude, so would appreciate anyone's thoughts/ideas/insight.
Thanks for the help,
Larry
Larry
on
RE: High pitched whine at 70-75mph
All Rover's t/cases have a little whiney to them just because they are an all geared case, not chain driven.
Are you sure it is the t/case, have you checked and rebuilt your front drive shaft yet, they can do this noise also.
Crawl under and see if the u-joints in the double cardon that hooks to the t/case have grease fittings, if they don't, I would suggest you get it rebuilt asap even if it is not the problem,cause when it fails, and they all do, it can destroy the tranny at the same time.
Mike
Mike
I know this is going to sound crazy, but just listen to this ...
I have a 2002 Disco II, and I also get a little bit of that high pitched whine at higher speeds... and it's exactly as you described - meaning that when you step on the accelerator, it gets a little louder, and when you let off the accelerator it goes away...
So ... try this. Turn off your radio completely, and then go drive at the higher speeds and see if that noise is there... for me, it goes away ... which leads me to believe that it's engine noise coming thru your stereo speakers. I'm planning on adding one of those noise filters to the power line of my stereo to see if it gets rid of the noise ...
Now, I don't know enough about the drive systems of vehicles, much less of the Land Rovers ... but it seems to me that if you heard a whine at that rate of speed, it wouldn't be due to stepping on or letting off the accelerator ... because either way, the gears and drive shaft(s) are still moving at the same rate of speed whether or not you're rev'ing the engine up ... but then again, like I said, I can't say that for sure ... I'd be willing to bet that Disco Mike knows more about this and can give us some insight...
on
Two thoughts about Rover drive train noise. With a full gear t/case Rover is known to whine, because it it is a full time 4wheel drive system you can also get a clunk in the drive train if you back off of the gas and then hit the gas again.
Also we are blessed with a cheaply built front drive shaft from Rover, the double cardon joint that contains 2 non serviciable u-joints will get noise and vibrate then fail which can take out the tranny also. If your u-joints don't have grease fittings, get the shaft rebuilt ASAP with # 344 u-joints with grease fittings.
If that shaft fails a high way speeds it can cost upwards of $7000 to make the repairs.
Mike
Mike
ORIGINAL: LMcInnis
