Sponsored by: CARiD
How to disable steering wheel radio control
Old Mar 10, 2010 | 12:55 PM
miamihi420's Avatar
Default How to disable steering wheel radio control
My 2001 Disco is having issues with the steering-mounted radio control. It is jammed and I can't change the station or lower the volume. I took out the fuse because the volume is stuck too loud and the station is stuck to one particular station that I don't listen to. I figure if I bypass the steering wheel control I should be able to get the radio to work since it was working just fine prior to the incident. Any suggestions?
Old Mar 10, 2010 | 05:35 PM
Remove the airbag cover and unplug the controls.
There are 2 bolts on the back of the steering wheel, the cover will come off and the wire harness should be right there.
Make sure you unhook the trucks battery for no less than one hour before you start so the air bag does not go off in your face and shove a screwdriver through your skull.
Old Mar 11, 2010 | 03:26 PM
salve7's Avatar
That would suck...
mdf27
Dec 18, 2015 11:00 PM
mattmo78
Mar 26, 2014 01:17 PM
southfloridadiscoII
Jun 28, 2009 11:03 PM
carlitonsky
May 27, 2009 10:12 AM
catchmyktm
Jun 5, 2008 02:16 PM
