How do I remove the rear driveshaft?
there are 6 bolts that hold the r/f to the flange......3/4" hex size or 19mm.....remove all 6, force the driveshaft forward to slide the shaft off of the centering bearing....if your front u-joint is ok....there is really no need to remove the joint end of the shaft.
having said that....if the shaft wont slide forward>>>.maybe it hasnt been greased in forever....and you'll need to remove the u=joint end anyway
MAKE SURE YOU CHOCK THE WHEELS BEFORE STARTING THIS OPERATION,I happen to know "a guy" who didnt do this a few years ago and the truck rolled over his foot...
The following 2 users liked this post by XCELLER8:
JUKE179r (08-29-2017),
KansasTrails (10-12-2016)
mark the shaft halves if you attempt to pull them apart...they are splined and should only fit back together well , one way
if you replace the u-joint with a chinese one from any of the cheap parts places the Rover Gods will get you !
robert.juric
11-03-2022 06:08 PM
bcolins
06-29-2015 07:22 PM
wheelgarage
10-01-2011 03:12 PM
