Sponsored by: CARiD
How to replace O2 sensors?
Old Jun 9, 2009 | 07:27 PM
baburhan's Avatar
Question How to replace O2 sensors?
Hi there,
I have a 2003 Disco with 110,000 miles. Recently, the CEL came on. Got the codes from Auto Zone: P0154 and P0174. I guess I need to change all 4 O2 sensors! Based on the forum, it sounds like I need to change them all at the same time. Am I correct?
Does anyone have a link to a step-by-step directions on changing the sensors? I really would like to do it myself and save some money!!!
Any help is greatly appreciated.
Thanks
Bob
Old Jun 9, 2009 | 07:36 PM
You should change all 4, yes, but that may or may not correct the lean run on bank 2.
Rover connection has about the best price for the 02 and they are fairly easy to replacing, usually only needing a little penetrating fluid to break up the rust.
Old Jun 10, 2009 | 06:49 PM
baburhan's Avatar
Thank you Mike. It sounds like it is not a terribly difficult job but do you have a link that shows how to change the sensors? Also what are the possible reasons for my other lean run on bank 2? By the way, the CEL is now off but it's just a matter of time for it to come back!
Thanks again for your help. It is greatly appreciated.
Bob
Old Jun 10, 2009 | 07:17 PM
Could be the 02, if not then you would want to look at the engine for vacuum leaks or a MAF that is starting to fail.
Old Jun 11, 2009 | 06:36 PM
baburhan's Avatar
Question
Thanks again... Can anyone tell me where they are located and how long do you think it would take to replace all 4 O2 sensors?
jsyonker
Sep 4, 2011 06:01 PM
elboy0712
Dec 19, 2010 02:48 PM
Disco2Fever
Apr 16, 2010 02:01 PM
JRdisco1
Aug 9, 2005 03:33 PM
