Sponsored by: CARiD
I’m an idiot. How to get something trapped out of fuel hose line?
Old Jan 27, 2021 | 05:55 PM
ToiletDuck's Avatar
Default I’m an idiot. How to get something trapped out of fuel hose line?
I was putting a fuel additive into my discover V TD6. The little flapper that’s on the tank under the gas cap (to keep you from putting gas into it) closed and took a plastic lid cap into the hose. I can put about a half gallon in before the system back fills and hits the pump handle shutting it off. Then I have to let it drain. I’ve tried a tool grabbing flex arm of about 3ft then took fishing tape and shoved it all the way down till it wouldn’t go any further which was several feet. I never felt this damn block but I still can’t really get fuel in it. Anyone know how to access the fuel “pipe” or hose or whatever? Can I pull the fuel door off, remove the rubber covering, somehow remove the fuel mechanism that has the flapper where you put the pump in, or remove segments of the line to the tank?
I have a lot of tools but I can’t find any info on how to do all of this. Schematics on how to access parts, etc. Willing to take any help!
Old Feb 1, 2021 | 06:27 PM
Rob.94's Avatar
5th Gear
Not sure if this would work, but I wonder if you could duct tape an old garden hose to a shopvac. I'm sure it would pull gas in, but if you have a low fuel maybe not. If you just turned on for a few seconds and just pulled the hose out maybe the cap would be on the end?
Old Feb 9, 2021 | 02:30 PM
Harvlr's Avatar
Do not try sucking a gas hose with an ELECTRIC vacuum! The fumes will ignite and you may have a disaster!
ReconDoc83
Jul 18, 2020 10:50 AM
Bob Florence
Oct 26, 2019 07:19 AM
geek_IM
Mar 31, 2018 03:03 PM
spurcap
May 26, 2016 11:15 AM
old gold
Jul 29, 2011 11:57 AM
