Sponsored by: CARiD
idle control valve
Old Jan 30, 2007 | 09:22 AM
vtrange's Avatar
5th Gear
Default idle control valve
95 4.0L range
Stalls at stops. Removed and cleaned the idle control valve as best I could, but it didn't help. Now check engine light is on. It wasn't before I removed and cleaned the valve. The air filter is fairly clean.
What else can I do?
Lee
Old Jan 30, 2007 | 12:10 PM
Default RE: idle control valve
Check for codes, if you have them what are they? Have you checked all your vaccum lines, cleaned the t/body plate?
You may have a bad idle control unit.
Mike
Old Jan 30, 2007 | 02:27 PM
vtrange's Avatar
5th Gear
I don't know what the codes are. I'll have to bring it to a shop for that. At that point they'll
probably just tell me what's wrong and I'll probably be able to fix it. Is there any other way to retrieve the codes? I'll look at the vaccum lines but I didn't hear any leaks. And I'll clean the t/body plate. I'm thinking that idle control is shot. 120K....
how much for one of those?
Thanks
Lee
Old Feb 8, 2007 | 06:54 AM
austech's Avatar
7th Gear
hi guys, the idle air control valve needs to be set by steps on a diagnostic machine, you could try yourself but im not surehow your rules are on emmisions, there is an allen key in the plemium chamber, probly covered by a blanking plug just wind it out slowly untill it idles nice but i still think u need the light to be cleared, please post me back and let me know how u go
Old Feb 8, 2007 | 09:53 AM
I agree with Austech, also just to make sure everything is OK, remove the air intake hose and clean out the throttle plate real well with some carb spray to insure it is closing all the way and not effecting the idle.
Mike
Old Feb 8, 2007 | 02:26 PM
vtrange's Avatar
5th Gear
Got it! Thanks for the help. I removed and cleaned the unit and cleaned the throttle plate. The plate seemed to be the key.
I didn't have to adjust that allen, but it's nice to know it's there. The truck is running really well now. The check engine light did come on and go off so maybe there is something else that needs to be done.
Again, thanks for the help.
Lee
discoboy
Feb 7, 2009 04:56 PM
nojeep
Jan 22, 2009 04:13 PM
flavorking
Feb 10, 2008 12:33 PM
bearcatfans
Dec 18, 2007 09:01 PM
bigugly82
Aug 24, 2007 01:26 PM
