Sponsored by: CARiD
Location of idle control valve
Old Jan 19, 2009 | 04:57 PM
nojeep's Avatar
8th Gear
Default Location of idle control valve
Hey fellow forum enthusiasts! Problem: I'm trying to solve the problem of high /excessive rpm on my wife's 1997 RR 4.6 HSE. Previously it was suggested that I check for vaccum leaks and also clean out the throttle body and checkthe idle control valve. Well I'm going to change both breather hoses that connect to the valve covers (as one has a hole in it and the other is clearly deteriorating due to gunk). In checking the idle control valve...I'm specifically checking for what...build up?
Old Jan 22, 2009 | 04:13 PM
bonnettoboot's Avatar
Default RE: Location of idle control valve
There is no idle control valve on your car, you can adjust the throttle cable on the quadrant on the air intake bseide the cruise control cable. It is more likely to be a vacuum leak, changing those hosesmight fix it.Is the check engine light on?
________
Mantis
austinlandroverbill
Apr 1, 2015 06:26 PM
charcoal grey
Apr 7, 2009 02:10 PM
Roveroh
Aug 7, 2008 09:42 AM
bigugly82
Aug 24, 2007 01:26 PM
vtrange
Feb 8, 2007 02:26 PM
