Sponsored by: CARiD
Intermittent Rear Shock Deflation
Old Jan 13, 2015 | 01:44 PM
ugottatri's Avatar
Post Intermittent Rear Shock Deflation
Without and Rhyme or reason my rear drivers side air shock fully deflates and passenger side partially deflates (it's like it tries to compensate maybe because of the leveling system?) then stays flat and without any warning, it will re-inflate again and be fine for a while until something triggers it then it goes flat again. Any idea what may be causing this? I live in ND and it definitely happens more often when the weather gets really cold.
Can anyone possibly shed some light on this?
I also have been researching spring conversion but it doesn't appear there is an EAS override for anything before 2005, is that correct? How do I override the EAS if I do go with the conversion?
Thanks in advance for anyone's help.
Old Jan 13, 2015 | 04:42 PM
dusty1's Avatar
check for leaks the same way you do in a tire. soapy water squirt bottle.
could be, bag, lines, valve, or even compressor.
conversion will usually set off a light on the dash. no biggy. I've had that light for a while. dealer visit or someone with a nanocom or other capable device can tell your computer that you are without bags and all is good
Old Jan 13, 2015 | 10:31 PM
ugottatri's Avatar
My confusion is why do the bags stay inflated sometimes and then deflate at others.
Old Jan 13, 2015 | 10:32 PM
ugottatri's Avatar
With that more than likely point towards a valve problem?
Old Jan 16, 2015 | 07:26 AM
drowssap's Avatar
the system self checks itself and levels back out
Old Jan 17, 2015 | 10:40 AM
ugottatri's Avatar
It doesn't level out one bags fully deflates and the other one deflates down to its lowest level
Old Jan 17, 2015 | 05:44 PM
OffroadFrance's Avatar
If the bags are 10 years old or more they've done well and need changing. LR recommends every 5 years. The bags roll over themselves and often 'self' seal but it's not a fix. Run the offroad lift to jack up the rear and check the bags with water/washing up fluid mixed 50/50 brushed on heavily and inspect for bubbles = leaks. My money is on your air suspension bags being past their useable 'sell by' date. They are easy to swap out and the whole process including painting the top and bottom locations takes 2 hours per side and costs you about $200 in parts in total. Not worth messing about with if they are old or original.
Old Jan 19, 2015 | 02:58 PM
ugottatri's Avatar
France......I'm relatively new to all of this so I've got a couple questions.
1. Painting the top/bottom? Explanation?
2. Every place I look, it's $150 to $200. Is that per shock or for a set of 2?
Where can I find comprehensive instructions on replacement?
Nfbeckman
Mar 20, 2010 07:38 AM
Chrisinhouston
Jun 13, 2009 07:27 AM
cosmickites
Defender
Oct 13, 2008 12:52 PM
Jantiz
Mar 5, 2007 05:33 PM
