Sponsored by: CARiD
latest quirk
Old Oct 18, 2008 | 08:13 AM
Rich 00 DISCO's Avatar
Default latest quirk
2000 123Kdisco is now doing another odd thing. Temp gauge, which has been rock solid center for past 60K (my ownership) now dips low to bottom of operation range (within brackets, not to cold) and drifts around between center and there. I'm thinking sending unit, thermostat. Any ideas - am I in any danger?
Thanks
Old Oct 18, 2008 | 08:47 AM
Adz's Avatar
Adz
Default RE: latest quirk
Thermostat is most likely stuck open... bet it takes a good drive to start warming up too? Does it blow cold air through the heater?
Stuck open is less of a problem than stuck closed... but stuck is still stuck. Replace as soon as you can
Old Oct 20, 2008 | 12:47 PM
Thank you, Sir. Finally, something that doesn't sound like $500!
Old Oct 20, 2008 | 01:18 PM
First go check and see if your coolant bottle is completely full, if not fill and bleed it cause you may have air trapped in the system and the temp guage can't read the coolant temp.
blackbirdindustries
Mar 30, 2010 11:50 PM
NM-DiscoDuck
Feb 20, 2010 01:26 PM
RoveringAgain
Jun 16, 2009 02:57 PM
luxury1
Jan 6, 2009 09:47 AM
AK Rover
Jan 3, 2009 03:20 PM
