Sponsored by: CARiD
Leak discovered while draining oil.
Old Jan 23, 2026 | 08:44 PM
mbjorlie's Avatar
Default Leak discovered while draining oil.
2006 LR3 SE 4.4 V8. I discovered a leak as I was loosening the oil drain plug. I believe it’s coolant…I’m new to all things Land Rover and need any advice I can get. Thanks!
Old Jan 28, 2026 | 06:27 PM
TBburg's Avatar
The factory coolant is pink, and leaves a pink/red stain. If that’s coolant somebody swapped in different coolant or mixed it. Check your tank up top to see what color it is. The drip in your photo almost looks like the power steering fluid they use.
There are several plastic piping bits that deteriorate over time and crack. Pull the plastic engine cover. If you’ve got the pink coolant any leaks on top will be very visible. That’s where I’d start.
Abandisco
Oct 10, 2024 12:29 PM
Dai20bt
Sep 29, 2022 12:14 PM
rud3dog
Jun 8, 2022 10:21 AM
BlackShama
May 26, 2022 10:20 AM
Sabbe
Oct 14, 2021 08:11 PM
