Sponsored by: CARiD
Leaks
Old Mar 4, 2015 | 09:39 PM
mrutland's Avatar
7th Gear
Default Leaks
I have an 02 discovery II SE. I have two water leaks when raining and I have not figured out where they are coming from. The first is dripping into the passenger side floor board. It is dripping onto the top and middle of the floorboard floor mat. Frame weld leak? or windshield not sealed properly?
The second leak is coming in on the passenger side seat belt assembly where the belt comes out just below the head board. Could this be coming from the sun roof somehow?
Old Mar 5, 2015 | 05:43 AM
dusty1's Avatar
Sunroof is probable suspect for both, though a leaking windshield gasket is less common, it does happen.
You are going to need to drop the headliner and address the issue...could be just a clogged/broken drain tube
Old Mar 5, 2015 | 06:26 AM
drowssap's Avatar
also check the caulking in the roof gutter there was a TSB on that
Old Mar 10, 2015 | 01:02 AM
frankie_500's Avatar
Yes, check your drain tubes, it might need cleaning or replacement. If you're able to locate where the leak is coming from, there's windshield adhesive for that. Your truck will be vulnerable to rust, so i suggest you try to keep it in a dry space while the leaks aren't fixed yet.
Spencerfitch
Sep 27, 2020 12:17 PM
FlyingZebra34
Apr 22, 2013 12:07 AM
Derek
Feb 17, 2013 07:37 PM
discoboy
Dec 20, 2012 02:24 AM
bmwrovers
May 23, 2005 01:02 PM
