Sponsored by: CARiD
Leaky Throttle Body Housing
Old Mar 31, 2015 | 03:18 PM
mrutland's Avatar
7th Gear
Default Leaky Throttle Body Housing
I have a 2002 Discovery 2. The throttle body housing is leaking coolant after the engine has been running for a while. Looks like it is coming out around the two small hoses on the bottom of the housing. Does this mean that the engine is overheating? What is the fix for this issue?
Old Mar 31, 2015 | 03:32 PM
justryan's Avatar
Are you talking about around the square plate at the bottom ?
if so it may not be overheating YET !!! if the coolant runs out however...your screwed ...
normally there's a square gasket there under with 3 bolts , that leaks , check the hose clips on the hoses first ,or change gasket if needed..... clean surfaces properly , refit gasket and you should be ok ( you will have to drain the coolant before )
Old Mar 31, 2015 | 04:00 PM
OverRover's Avatar
FlyingZebra34
Apr 18, 2014 02:00 PM
SenatorPerry
Jul 15, 2013 10:28 AM
TripleThreat
Feb 19, 2012 09:14 PM
Desert Fox
Feb 27, 2007 12:35 PM
Doss
Mar 26, 2006 06:00 PM
