Coolant Leak below Throttle Housing
Old Jun 25, 2007 | 04:35 PM
TripleThreat's Avatar
Default Coolant Leak below Throttle Housing
I noticed today a coolant leak below the Throttle Housing. You can see the stream of coolant squirting out in the photo below...
Is repairing this as simple as replacing a gasket?
Jeff
Old Jun 25, 2007 | 05:08 PM
lxrules's Avatar
5th Gear
Default RE: Coolant Leak below Throttle Housing
It is actually an assembly that you end up replacing, about $24 at the local rover dealer. The part that is leaking is the pre-heat for the throttle body. I just had to replace mine last month and from what I gather is a rather common repair.
Scott
Old Jun 27, 2007 | 07:58 AM
vicki2's Avatar
Just had this done yesterday but it wasn't $24! Much more at the dealership but my Disco was in for a 60K tune up.
Also, they did a throttle body service while they were in there which the servicce tech said he recommended once a year for a Disco with more than 60K on it. Says it saves later on. That true?
Old Dec 15, 2009 | 03:37 PM
downee's Avatar
Hey
I am having the same problem, again, on my discovery 03 SE at 40k.
Would you please share how's your problem to be solved? and how much that cost you? thank you very much
Old Dec 15, 2009 | 03:46 PM
hilltoppersx's Avatar
yes and an induction cleaning, and dumping a can of seafoam in the tank. total cost $24. see Mike's 60k service sticky in the HOW TO section.
Old Dec 15, 2009 | 04:47 PM
jrkstore43's Avatar
Here is a pretty extensive post on this subject. It has been discussed numerous times in this forum...I'll be bypassing mine soon...just started leaking for the second time.
https://landroverforums.com/forum/sh...ad.php?t=18258
Old Feb 19, 2012 | 06:27 PM
seadevils21's Avatar
6th Gear
So do I take both hoses off the throttle body and then join them together with a copper tube???
Please help, FYI Im in CA it never gets to cold so I should not worry about freezing... Thank You
Brandon
Old Feb 19, 2012 | 09:14 PM
You can do that as a temp fix. But the repair parts kit is like $25. The freeze up would happen if you were in the mountains, pulling in cool air, get to the top of the mountain, start down the other side, and throttle is still stuck almost wide open. Have seen posts where this can happen at like 36F with right humidity. See Throttle Body Heater Plate Kit | Land Rover And Range Rover Fuel System Parts
mrutland
Mar 31, 2015 04:00 PM
conmetal
Jan 14, 2013 10:16 AM
KyShark
May 23, 2011 09:59 AM
boom_r6
May 1, 2010 07:41 AM
ggothlin
Jan 2, 2010 02:06 PM
