Leaky Valve Cover Gaskets
GASKET INLET UPPER-LOWER P38A RANGE ROVER & DISCOVERY II V-8, RND308, ERR6621 - Rovers North - Classic Land Rover Parts
i was referring to this ^ little guy
well, then. it is a good time to swap plugs and wires, while you have the upper intake off, if that is on your agenda. people like to complain about the difficulty, in accessing the coil packs, otherwise. i do not find it to be that bad.
magnacor or kingsborn 8mm are the suggested, for wire.
suggestions are all over the place for plugs. I have run champion cheapoes and now some bosch iridium things......only difference, I have noticed, is the price.
RROJ
Mar 26, 2011 02:37 PM
