Sponsored by: CARiD
LR3 front air suspension swap
Old Mar 18, 2013 | 01:32 PM
discoland's Avatar
Default LR3 front air suspension swap
I am planning on replacing both front air suspensions on my 2006 LR3 and was wondering if I should buy the genuine Land Rover or get the Arnott.
Reason why I am replacing both is that the front driver side suspension is leaking. I did check the valve block and the air line connections for leaks and did not see anything wrong. The truck height drops overnight on the driver side, even with battery disconnected.
Does anyone have any feed back on the Arnott or any advice on going one way or the other?
I am planning on doing the job myself, any tips are welcome.
Thanks for your input.
Old Mar 18, 2013 | 05:47 PM
Rovin4life's Avatar
You can do just a bag kit if you want. but lots of them have rust issues so its a fair idea to do the strut as well. Arnott has good track record with land rover airbags. new ones are made from a delco
Old Mar 25, 2013 | 08:59 AM
discoland's Avatar
Default Update and bad front valve block
I have been digging into the drop on one side issue and found out that if there was no apparent leak that could be related to the front air valve block.
Anyway I decided to replace the block first before to dump $ 800 in new suspension.
Good news no overnight drop after the block was changed.
So it was probably an internal leak that was the cause of the suspension drop issue.
Replacement was pretty easy too.
TRIARII
Jun 30, 2022 09:48 AM
ljdiscovery
Feb 13, 2016 11:21 PM
bennyb43
Dec 11, 2013 08:17 AM
fastrx7man
Jan 28, 2012 12:49 PM
tripz
Jan 4, 2007 05:58 PM
