Sponsored by: CARiD
LR3 half shaft removal
Old Oct 2, 2013 | 08:23 PM
nwtrees's Avatar
3rd Gear
Default LR3 half shaft removal
I am replacing my front differential the shop manual simply says release the shaft from the diff housing but I can't get them to budge is there something I am missing or a trick? Help Please.
Old Oct 2, 2013 | 08:34 PM
The shop manual also shows a lot of specialty tools as well. Perhaps some our pro's finally home from the shop, will relax and comment. The poor rascals only work half days, the first 12 or the second 12...
Pages from manual atached, seems like curclip may be riding on something.
BTW, what prompts replacement of the diff?
File Type: pdf
Old Oct 2, 2013 | 08:55 PM
nwtrees's Avatar
3rd Gear
Started hearing a horrible grinding noise from the front end turned out the pinion seal leaked, and had lost most of gear oil what little was left was full of metal shavings.
Old Oct 2, 2013 | 10:18 PM
How many miles, and had you ever replaced the fancy fluid? I know they spec 150K, but it is less than a quart in there. How much did theparts set you back?
Old Oct 2, 2013 | 10:36 PM
nwtrees's Avatar
3rd Gear
We just bought it a few months ago with 120k so I don't know the history. I had been real busy and had jiffy lube do the last two oil changes so I didn't see the leak until it was too late. I will definitely be doing my own oil changes and will be changing diff lube every other oil change. found a used diff with 75k on ebay for $675.00 with shipping
Old Oct 3, 2013 | 12:45 AM
We have had reports of $2000 at the stealership. And I recall one guy who was given an LR3 by his brother (thanks, bro!), had diff serviced, left the west coast and was driving across Montanna when the drain plug wiggled out. Not a lot of dealers up there.
Old Jan 11, 2014 | 05:19 PM
nadroj's Avatar
I am stuck at the same spot. How did you release the half shaft???
Hossmans2000
May 4, 2014 10:44 AM
Aus-trek
Dec 31, 2012 07:56 PM
djessopeng
Sep 7, 2007 06:28 AM
DiRanged Rover
May 26, 2006 12:39 PM
DiRanged Rover
May 24, 2006 07:36 PM
