Sponsored by: CARiD
Lr3 shows suspension fault at 60kms to 80kms
Old May 29, 2019 | 10:30 AM
Nicepackage's Avatar
4wd High
Default Lr3 shows suspension fault at 60kms to 80kms
Hi all having a problem with red suspension fault but only at a higher speed it seems on the lr3. Did a hard reset, replaced relay for suspension under hood, know about tail light bulbs and parking brake sensor replacement. Due to the fact it happens at higher speeds could it be some sort of a speed sensor throwing up some suspension fault codes and if so is it possible to replace a speed sensor itself. On a side note were would this sensor be in order to replace it?
Altitudes
Apr 15, 2019 08:38 AM
jophess17
Apr 27, 2016 01:01 PM
PeterOZ
Feb 3, 2013 08:04 PM
chris_craft
Jul 30, 2008 09:07 PM
