Sponsored by: CARiD
LT77 2nd gear problem! PLEASE HELP!!
Old Dec 27, 2014 | 11:27 AM
emanname's Avatar
3rd Gear
Default LT77 2nd gear problem! PLEASE HELP!!
An issue I'm worrying about on my LT77 is the 2nd gear crunches/sticks a bit while engaging from 1st to 2nd, Sometimes it shifts smoothly and sometimes doesn't but when you engage it slowly (from 1st to 2nd) it shifts smoothly with no crunches at all is this normal? Recently I have changed Gearbox oil and Transfer box oil with no difference at all. Shall I get used to it or its something major?
Attached Thumbnails LT77 2nd gear problem! PLEASE HELP!!-68322_10151096910636791_1946860318_n.jpg
Old Dec 27, 2014 | 12:42 PM
Probably the synchronizer going out.
Old Dec 29, 2014 | 09:51 AM
jafir's Avatar
That would be my guess too.
Another possibility might be clutch hydraulics, or maybe even the clutch fork starting to fail. If you pump the clutch pedal a couple of times, does it get easier to shift?
Does it get better after you drive it for a few miles?
DanB
Jan 28, 2014 10:06 AM
freeland02
Engine & Internal
Nov 25, 2007 04:44 PM
rumpig70
Nov 15, 2007 03:22 AM
lugo35
Engine & Internal
Dec 13, 2004 05:51 PM
