Sponsored by: CARiD
'M' transmission mode & HDC
Old Nov 6, 2007 | 06:41 AM
bearcatfans's Avatar
Default 'M' transmission mode & HDC
I just purchased a 2003 Discovery SE7 with 73000 miles but I have some issues. Supossedly the 'M' transmission mode can be engaged by pressing the 'Mode' switch while in Low Gear using the gearbox lever. When I enter the Low Gear and press the 'Mode' switch, all i get is the 'S' lighting up. I thought that sport mode only works in 'High Gear' and manual modewill workin 'Low Gear'. What is going on?
Secondly, the HDC (hill descent control) will not operate. I enter 'Low Gear' and press the HDC button anddescend down a steep slope. All that happens is the green HDC light flashes and the warning chime sounds. The HDC wont work!
Any thoughts?
Thank you,
Aaron - new Disco owner and loving it so far......
Old Nov 6, 2007 | 07:06 AM
Default RE: 'M' transmission mode & HDC
You mus have the t/case in low gear to make either of these functions work.
Old Nov 6, 2007 | 07:25 AM
Thanks for your quick reply Disco Mike,
Yes , I had the transfer case in Low Gear and the 'M' mode indicator light will not come on, only the 'S' mode light illuminates when the mode button is pressed-----and the HDC will not operate, the green indicator light only flashing and a warning chime continuously rings until I turn off the HDC switch - so neither of these options will function with the t/case in Low Gear...
What can I do?
-aaron (frustrated)
Old Nov 6, 2007 | 08:30 AM
Do you have any ABS warning lights on?
Old Nov 6, 2007 | 09:45 AM
There are no ABS warning lights that are constant, but the "three amigos" have showed themselves about 4 times since I bought the truck last week ....Last Friday , went to the dealer - the Dealer pulled/cleared the ABS codes and said that none were present. The '3 lights' came on yesterday morning but went off after I restarted the car. Theyare not illuminated whenIshift the t/case into Low Gear and try to activate the "M" mode or the HDC.....
I need help [&:]
-aaron
Old Nov 7, 2007 | 03:25 PM
bavarian_range89's Avatar
Sorry for my lack of knowledge, but what are the three amigos? I have three lights and will sometimes illuminate when I first hit the brake and they immediately go out. It is the traction control, abs, and parking brake light and they will flash sometimes when I hit the brake. Are those the three amigos?
Old Nov 12, 2007 | 09:13 PM
Hello,
I don't understand it but tonight I engaged the transfer case into 'Low Gear' to try the HDC and 'M' mode and the BOTH WORKED!!
????????? (I still have the intermittent 3 amigos though....)
-Aaron
Old Nov 13, 2007 | 06:55 AM
Aaron, still need to get your truck in the shop when the lights are on so you can find out what is causing it.
Let us know what you find out.
Old Nov 13, 2007 | 08:10 AM
dkeach's Avatar
ORIGINAL: bavarian_range89
YES
angasreid
Dec 16, 2023 07:45 AM
aircraftguy
Feb 19, 2022 08:22 AM
cmossman
Jul 19, 2010 03:06 PM
bearcatfans
Dec 11, 2007 08:55 PM
yarddawg
Dec 10, 2007 05:19 PM
