Sponsored by: CARiD
MAF worn, will driving cause problems to Disco 2?
Old Dec 17, 2007 | 09:37 PM
Testpilotb's Avatar
7th Gear
Default MAF worn, will driving cause problems to Disco 2?
Want to say hello and thanks for such a great forum.
Lurking has helped me realize that I have all the codes needed for a MAF sensor problem. p0171 and 174 and the 3rd 4th gear code.
Just had the head gaskets and valve work done, along with the timing chain and oil pan gasket. Full engine/cooling system flush
Bottom end looked great. NEW plugs, and wires are less than a year old.
I HAVE a new MAF sensor on the way, but can I drive my Disco 2 (2000) without causing any damage in the meantime?? I dont want to undo all the work done. THANKS
Dave
Old Dec 18, 2007 | 08:58 AM
Default RE: MAF worn, will driving cause problems to Disco 2?
For a couple of days, you'll be fine.
Chimchase
Freelander
Sep 1, 2019 11:07 AM
potatoes
Feb 19, 2014 10:22 AM
smigel
Sep 26, 2007 09:11 AM
sharbel
Dec 7, 2006 10:22 AM
