Sponsored by: CARiD
Malfunctioning immobilizer/key
Old Jan 4, 2014 | 09:27 AM
NorwegianDisco's Avatar
3rd Gear
Default Malfunctioning immobilizer/key
I've got aproblem with the immobilizer on my Disco 2 2001.
I just bought it yesterday (my first LR ) and had a couple of stops on the way home. I had no problem starting the car or locking/unlocking it with the remote key. But…
When I got home, the car wouldn't lock with the remote. Later it wouldn't start. I can manage to fool the immobilizer by disconnecting the battery. When I reconnect Ican turn the engine on within 30 seconds. When I turn the engine off again, the immobilizer sets in 30 seconds after closing the door, and I'm back at thestart.
I'm lookingfor an easy and cheap fix. Either I want to get the immobilizer working again,or I want to bypass it. Another problem is that the key doesn't turn in thedoor (I'm going to try lubricating it), so preferably I'd like the remoteworking again.
I've read that the IDM/fuse box can create problems if moist?
I also read something about the crankshaft position sensor, but I doubt it should affect the immobilizer, or am I wrong?
I'd be extremely happy for any clues, ideas, suggestions or anything J
Old Jan 5, 2014 | 08:33 AM
Shop manual and electrical guides in the RAVE which has links below (Rover name for shop manual set). Door switch is most likely issue, it has a tiny contact that signals the system to unlock/lock and thereby mobilse/immobilise.
There is no bypass. The ECU is built to exchange digital data with other modules.
CKP sensor sows up as no crank when engine hot at first. Won't have sparks.
Old Jan 5, 2014 | 12:11 PM
3rd Gear
Thanks for the reply!
So you suggest that the door switch immobilises the system/engine? Could it be any of the five doors? What's the logic behind this?
I'll check the RAVE, thanks again!
NorwegianDisco
Mar 9, 2014 08:54 PM
castillo8071
Nov 13, 2007 10:54 AM
drhunter
Sep 7, 2007 08:24 PM
jasongilliland
Oct 4, 2005 12:22 AM
jasongilliland
Sep 15, 2005 05:37 PM
