Mass Air Sensor
Hopfully some of you with more Land Rover experance can help. The 1999 Discovery stopped starting , will it would start then die, no codes. After unpluging the Mass Air Sensor MAS
it would start and run , drove 225 mile before I got a code p0101 and P0102 So aat this piont I hoohed the MAS bach up vehicle starts and runs,
after about 25 miles code p0102 back.
Have any of you had Mass Air Sensor code 0101 and cdoe 0102 . It is not the MAS it has been replaced. Is their a place in the wiring to look for a bad connector/ shout/ bad ground
a place to start looking? I have another Rover and plan on swaping the ECU's as a last resort test for the ECU. Rovers are 1998 and 1999 Discovery 1 . To be sure the ECU is the
black box on passanger side / right side behind glove box?
I found this company do you or anyone else know anything about them ? or have reconditions?
https://www.g7computers.com/collecti...cts/land-rover
