Sponsored by: CARiD
Need help with 2001 Discovery 2.
Old Aug 24, 2018 | 02:09 PM
Terrbear44's Avatar
3rd Gear
Default Need help with 2001 Discovery 2.
Vehicle starts in the morning when the engine is cold. Drive it for 5 miles turn it off and it will not restart. Put a new fuel pump in it. Apparently that wasn't their problem. Fuel pump gets power when engine is cold. Once the vehicle is driven for a few miles the fuel pump does not get power. Have power from the ignition to the relay but no power from relay to the pump. Once it sets in the engine cools down. It will start again. Any help would be greatly appreciated.
Old Aug 24, 2018 | 05:43 PM
The Deputy's Avatar
Does it quit going down the road, or just not restart after warm?
Might be the crank sensor or wiring to sensor.
Brian.
Old Aug 24, 2018 | 06:47 PM
Terrbear44's Avatar
3rd Gear
Thank you deputy.
it has stopped twice while I was driving down the road. Never made it more than 4 or 5 miles.
I will check the wiring from the relay box to the fuel pump. I read where someone had the same problem and the wire was up against the catalytic converter. Kind of sounds like something like that because it's fine until it gets warm. Thanks again I will try what you said. Will let you know the results.
Old Aug 24, 2018 | 09:43 PM
sounds like the cps to me to
Old Aug 24, 2018 | 09:52 PM
Terrbear44's Avatar
3rd Gear
Thank you very much Army Rover. I will definitely be giving that a look at in the morning.
Old Aug 25, 2018 | 06:19 AM
JUKE179r's Avatar
Crankshaft position sensor - Bosch #ERR-735
Sarahcake
Mar 2, 2016 10:24 PM
dc10freighter
Aug 6, 2012 01:09 PM
bilmgl
Oct 18, 2011 08:36 AM
airic
Jan 18, 2009 08:07 AM
taylorhertz123
Jan 4, 2009 09:06 AM
