Need help with a knock
Just bought an 04 D2 with 130k miles. It had a mild engine rebuild last year due to a slipped liner. I've changed the oil to rotella 15w-40 and a quart of MMO. Seafoamed it and cut off the cats (they were making noise and were severly clogged). There are no exhaust leaks that I can detect. So, the problem is it has a slight knock. On a cold start it idles quietly, when revved a faint knock can be heard when it is going up the rev range. If I hold a steady rpm, no matter what rpm- no knock. When in gear it is more noticeable, but goes away (seemingly) at rpms over 2500. After driving for about 15 mins it is significantly quieter. When on the interstate it isn't noticeable. I have used a stethoscope and heard it around the back of the engine to the bell housing. I can't tell which. I took the inspection plate off the bell housing, but didn't see any noticeably loose tc bolts. I'm at a loss. The oil pressure seems to be ok. The light goes out immediately at start up. I ordered a gauge just to be sure. My next move will be transmission fluid and filter change. Any thoghts? TIA!
It is so hard to tell by hearing it in a video.
My winter van at work had a similar noise, it has a Duramax.
When the transmission was being replaced we had them take a look, sure enough, cracked flexplate.
Trans was already out so had it replaced, noise went away.
It had been there for years, only reason it was replaced was because the trans was already out.
