Sponsored by: CARiD
Need some help, decelerating noise
Old Dec 11, 2008 | 08:14 PM
Elliot214's Avatar
5th Gear
Default Need some help, decelerating noise
Hey guys well I have a 1999 Discovery LSE and I need some help. I have noticed that recently whenever I let off the gas the car vibrates and there is a rattling/grinding noise coming from the undercarriage. Sometimes it sounds like the brakes (two pieces of metal rubbing together) but sometimes it sounds like something is caught. The best way i can describe it is like when you were a kid and put a playing card on your bicycle wheel to make it sound like a motorcycle. It seems to be coming from the bottom or maybe the rear of the car. I have gotten under the car but I cannot find anything that might be rubbing against the wheel. Once again, it only happens when I start slowing down even if I do not touch the brake. I am going to the Rover shop next week but I am really concerned. If anyone has any idea please let me know, I really appreciate it!
Old Dec 11, 2008 | 08:20 PM
TD4141's Avatar
Default RE: Need some help, decelerating noise
possibly a U joint going bad.
Old Dec 12, 2008 | 10:28 AM
Have you replaced the 2 greaseless u-joints yet, if not, stop driving the truckTODAY so you don't loose your tranny also.
How often do you lube your u-joints, check your roto flex and see if there are cracks between the 6 bolts.
Snafu / Disco Fries
Jan 14, 2015 09:11 AM
Eaglerover22
Apr 9, 2012 03:55 PM
poddo
Feb 15, 2011 08:57 PM
Billabong
Jan 27, 2010 12:36 AM
97DISCOIDAHO
Sep 8, 2006 11:56 PM
