New Disco Owner-Heads up?
Hello all!
I just purchased from family a 2003 Disco 2 HSE with 59k. It's mint, runs and drives perfect, and has all records. Want to cover my six and make 'er last and long as I can.
Can you pro's give me a heads up as to what I should be looking out for...common serious problems or what not? I am new to Land Rovers and I just don't want to go about this blind! It's getting ready to have the 60k treatment performed based on what I have found here on the forums and I'm competent in my abilities, however I'm not afraid to ask for help when I'm learning about new vehicles which I am here!
Any input would be greatly appreciated and I will share all that I learn on my own and with the help of you guys here on the forums.
Thanks in advance!!
Thanks in advance!!
03's have had a number of engine failures, so call the dealer with your vi. number and see if your is on the list of possible failures.
You will want to either rebuild or replace the front drive shaft, if it only has 1 instead of 3 grease fitting cause it will fail and take your tranny with it.
Lastly look for my 60K service list in the Discovery section and do the entire list. If you have any questions, shout.
Ok...front drive shaft....check. I did read a write up on the engine failure mess...just was unaware that my VIN would define wether or not my Disco could have the illness! I still have a little over a year of warranty remaining...if mine should fall into the "engine failure category" would the dealer do the engine before it fails or would I have to wait until it happens--which would probably be right after the warranty goes out?
And lastly......when I call the dealer with my VIN....what should I ask and be on the lookout for? Will they be straight up with me or are they gonna say "Oh, with such low miles you should be ok" only to have it fail 3k miles later?
Thank again for the info DM...very helpful!
Cheers
VCD Problem!?
Alright,I know there are DVDs but if I wanna save it to my computer,I have to rip it and it's very troublesome. So,I brought this Flushed Away VCD. So I need to trim the front(I use windows movie maker)because those I don't need. But when I trim the front,everything goes blank(the audio and sound is still there)! so I have to press the undo button and it comes back. I need to upload this video to Youtube.So,if I cant trim the beginning,I can't trim the movie to parts and I can't upload the WHOLE movie!
grandkodiak
Jun 15, 2011 07:20 PM
JBEGIN
Jun 27, 2009 12:38 PM
