no keys!!!
Do you happen to have your key code written down in your manual? I purchased a blank key fob for 130.00 and found out it would have to be programmed by Land Rover. I then purchased a key from a place in UK, that sends a programmer for the fob, and you return the programmer and they will send you the EKA code.(you must have a working key to turn the ignition on for this one) It was 180.00 and they refunded 30.00 after you send back the programmer.(there is a thread on this). Without the key code, LR Dealer may be the only option. and it is at least 300-400 from what i have read.
