Sponsored by: CARiD
no keys!!!
Old Aug 29, 2015 | 07:24 PM
dobe1canobe's Avatar
Default no keys!!!
does any one know about how much it costs to get new keys made for a 2000 disco? i lost mine at the river today......
Old Aug 29, 2015 | 08:44 PM
Joemamma1954's Avatar
Do you happen to have your key code written down in your manual? I purchased a blank key fob for 130.00 and found out it would have to be programmed by Land Rover. I then purchased a key from a place in UK, that sends a programmer for the fob, and you return the programmer and they will send you the EKA code.(you must have a working key to turn the ignition on for this one) It was 180.00 and they refunded 30.00 after you send back the programmer.(there is a thread on this). Without the key code, LR Dealer may be the only option. and it is at least 300-400 from what i have read.
Old Aug 30, 2015 | 08:31 PM
abran's Avatar
You can get a locksmith to come out and cut a key, I have a local one who charges $120.
In the meantime, if the car is unlocked, you can remove the ignition cylinder and turn the switch with a screwdriver so you can drive it.
Good luck. If you are in CA I can code a remote for you.
LR3PO
Feb 6, 2021 12:20 PM
east302
Feb 24, 2019 01:37 PM
SafariGal
Sep 24, 2006 12:35 AM
missoulanancie
May 1, 2006 05:27 AM
II2Go
Jan 10, 2006 05:32 PM
